Are you running one stick of 4GB ram or two 2GB sticks?
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/385217-help-me/#findComment-5200622
After the bios it shows startup repair or starts normally.i choose startup repair and it blue screen.
In the bios enable XMP, and or turn down the frequency of the ram to 1333MHz and try to boot.
Also please include
-CPU (overclocked?)
-Motherboard
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/385217-help-me/#findComment-5200738
I will update later,i'm reinstalling the 2gb ram because i have to use it for work.
If you can get it to boot, chuck us the latest file in C:\Windows\Minidump.
It basically tells us what was most likely to have caused the crash.
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
https://linustechtips.com/topic/385217-help-me/#findComment-5200905
After the 'A problem' paragraph it says IRQL_NOT_LESS_OR_EQUAL
TECHNICAL INFORMATION
***STOP:0X00000000A (0X00000000,0X000000002,0X000000001,0X85C71730)
sorry i dont know to attach picture i'm using my phone
that error happens when windows tries to access memory that it cant, could be caused by a bad driver or something.
can you get to safe mode? if you can, grab us the dump file and also what do you have installed on your computer?
https://linustechtips.com/topic/385217-help-me/#findComment-5201106
That's what's causing your system to crash - http://www.file.net/process/kbdhid.sys.html
The file is trying to be written to ram, but is having a problem. That's what's causing the crash.
Are you using two same sticks of ram? or miss-matched?
It's not a race to the bottom.
https://linustechtips.com/topic/385217-help-me/#findComment-5202431
I use one stick of ram
https://linustechtips.com/topic/385217-help-me/#findComment-5205800
No i cannot get it into safe mode and there is no file in minidump folder
https://linustechtips.com/topic/385217-help-me/#findComment-5207059
Although I doubt it, can you get to "Last Known Good Configuration"? (in the same menu as where safe mode and stuff is)
Download this http://www.memtest.org/download/5.01/memtest86+-5.01.usb.installer.zip and use the included tool to make a bootable flash drive
With the new memory installed run the tool for a few hours (and preferrably overnight), it'll check for bad memory.
https://linustechtips.com/topic/385217-help-me/#findComment-5207087
Can you tell me the settings?
You can look at the website that you bought it from and see if it has it.
Looking at the side of the ram will be easiest. It's normally on a sticker. It should say the speed, timing and volts. It will look something like 1600Mhz 9-9-9-24 1.5V (but not those settings exactly)
https://linustechtips.com/topic/385217-help-me/#findComment-5209266
