This is my first build. I use it to play games like Counter Strike: Global Offensive, Terraria, Minecraft (very little), and write papers for school sometimes. I want to stay under $850 USD. I need input on the build and what I should add and remove. Here it is:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($163.95 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($79.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($48.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card ($314.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($47.99 @ Micro Center)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($34.99 @ Newegg)
Case Fan: Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fan ($5.99 @ NCIX US)
Other: Windows 8.1 for students ($69.99)
Total: $828.85
Generated by PCPartPicker 2015-06-11 18:42 EDT-0400
https://linustechtips.com/topic/385061-1st-final-build-plan/
Check out reddit.com/r/microsoftsoftwareswap for a WIndows 8.1 key for $25 - save some money there.
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/385061-1st-final-build-plan/#findComment-5198693
Nice build for 800 bucks. If that's all you are going to play, go for a 960 or 280X. Also, save yourself 16 bucks and don't buy more fans. Use those savings and get a nice SSD. 120GB is going for around 60-70 bucks, while 250GB is going for around 100-120.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/385061-1st-final-build-plan/#findComment-5198744
If he stuck with the 970 he would be able to get into more gpu heavy stuff and be more future proof.
https://linustechtips.com/topic/385061-1st-final-build-plan/#findComment-5199062
Go for 2 140mm to replace the 120mm in the front and then use it for the top or back. You would then only need to buy 2 of the fans you wanted.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/385061-1st-final-build-plan/#findComment-5199205
