Dac Problem
![Fluffinator](http://pbs-prod.linustechtips.com/profile/photo-thumb-68732.jpg)
By
Fluffinator
in Audio
in Audio
Solved by creatip123,
Tubes gotta have a very secure connection points on each legs. Bad connections caused by loose clamps, dirt, gunk, etc, will destroy the resulting sound.
Try using these: http://www.amazon.com/Cary-Bakelite-Vaccum-Socket-Saver/dp/B00KOT96WA/I think they're cheaper on ebay. Just be sure it's the right leg (9 legs)
Lots of people use those to roll their tubes frequently. That way, the original clamps won't get loose by plugging unplugging the tubes.
Featured Topics
generic000 ·
Posted in Graphics Cards4 -
Cringe_Master245 ·
Rideonbrother ·
Posted in New Builds and Planning1 -
2
4
Gas Racing ·
1
2
1
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
