Guys help me decide :/
Looking for a slim cooler for a system I'm finishing, white and black color scheme and they both would fit very well :(
Slim Enermax ETS T40 White Cluster Slim Version Cooler
11148770_1012982285393684_86229189129070
or
Phanteks PH-TC14S, Slim Twin Towers Cooler
https://linustechtips.com/topic/383833-help-me-choose/
I would go with the phanteks since it has more heatpipes so better cooling.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/383833-help-me-choose/#findComment-5182200
At simple sight I'd go phanteks, but try to find a comparative done under the same circumstances, the conductivity also depends on the material the heatsink is done and other things
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/383833-help-me-choose/#findComment-5182226
um yea they are both great and its for looks here at this point
https://linustechtips.com/topic/383833-help-me-choose/#findComment-5182271
