so this is my pc, http://pcpartpicker.com/p/zxKPHx, mind you it was my first build, but it runs fine for me and it was a bit rushed. so my question is what mobo and intel cpu should i use if i want to play most or all games 1080p with 60fps and for work and rendering videos and such, i know my gpu isnt the best but i do plan on getting a better one as well. price range, around 800 for mobo cpu and gpu.
https://linustechtips.com/topic/383744-need-help-moving-from-amd-to-intel/
There you go:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.98 @ OutletPC)
Total: $467.96
Generated by PCPartPicker 2015-06-09 18:33 EDT-0400
Even with an Intel CPU, that GPU won't get you 60fps at 1080p in demanding games. Assuming you upgrade to something like an R9 290/GTX 970, and that you already have a good aftermarket cooler, I'd do this:
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Total: $312.97
Generated by PCPartPicker 2015-06-09 18:36 EDT-0400
Edited by Lotus
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.98 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard ($95.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($330.99 @ B&H)
Total: $683.95
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
Even with an Intel CPU, that GPU won't get you 60fps at 1080p in demanding games. Assuming you upgrade to something like an R9 290/GTX 970, and that you already have a good aftermarket cooler, I'd do this: PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.98 @ Newegg)Total: $312.97Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-06-09 18:36 EDT-0400
There you go:
Total: $467.96
he said, CPU GPU and mobo
Total: $683.95
thanks for including the gpu, and i like this, but wouldnt my noctua cpu cooler be compatible?
There you go:
Total: $467.96
This plus a Gigabye GTX 970
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
yes, but a 212 evo is good enough :) if you wan't you can throw in an 250gb 850 evo ssd. i would recomend it
He already has a better cooler.
Basically a 4690K and the Z97 mobo you most fancy. You can check Luke's value Z97 motherboard videos (parts 1,2,3).
I'd suggest waiting until the end  of the month for the GPU.
thank you, and why should i wait for my gpu? is there something coming out?
If you can keep your current mobo/CPU in another computer it would render videos really well. This would be great, the big thing is the GPU upgrade. The CPU upgrade is just kinda so that the 970 isn't bottlenecked. The CPU is definitely not the weakest link in your current build, it's that 270x
http://pcpartpicker.com/p/B8PsrH
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
so if i keep my build? what would be a good gpu upgrade?
Basically what I listed is perfect. If you want to upgrade your GPU, you'd want to upgrade your CPU as well so that it doesn't bottleneck your system. If you only have the money to upgrade one or the other right now, it'd be the GPU. Having an FX-6300 and GTX 970 for now would be better than an i5 and R9 270x, you'd just have to deal with the FX-6300 holding the 970 back for a little while until you can upgrade your CPU
BUT! If you play MMOs or like to emulate games, the i5 now would be much better since graphics in MMOs aren't usually a problem. The FX-6300 does very poorly when it comes to MMOs and emulation. (Most emulators are limited to dual-core usage)
If you can afford an i5 and GTX 970 at the same time go for both!
so just saying, what if i want an i7, since everyone has been showing me i5 only. shouldnt i just spend the extra 100 bucks for an i7 or does it not matter to much?
The i7 doesn't boast many advantages over the i5. It's an i5 with hyperthreading, which means anything using more than 4 threads will benefit. For video rendering sure it will be faster, but if you have to cut on the GPU it's not worth it. i5+GTX 970 > i7+GTX 960 in most cases
oh okay thank makes sense, thank you for helping me out
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($349.98 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card  ($314.99 @ Newegg)
Total: $804.96
Generated by PCPartPicker 2015-06-09 19:38 EDT-0400
I would go with something like this, if you do a lot of rendering on your PC you will benefit from the hyperthreading of the i7. You could also replace the i7 with the xeon equivalent if you have no desire to overclock.
