So i bought the razer carcharias, and when im playing talking to friends all good.
But when i turn off the computer the headphones led and power dosent turn off, can someone help?
CPU: Intel Core i5 650 @ 3.6 Ghz | CPU Cooler: Stock | Memory Ram: 8GB ddr3 1333mhz | Motherboard: Asus P7H55M-PRO | Graphic Card: XFX HD 5770 @ 900mhz | Storage: 2x WD Black 500GB | Mouse: Razer Deathadder 3.5G | Keyboard: Razer Blackwidow | Mousepad: X7 | Headphones: Asus Orion Pro
https://linustechtips.com/topic/38307-help-with-razer-carcharias/
>Razer
I'm so sorry. It sounds like USB is connected and your motherboard supports drawing power while the system is off.
Install Gentoo GNU/Linux | "You have been placed on moderator queue. This means that all content you submit will need to be approved by a moderator before it will be shown." | top LEL
Build specs: Corsair 540, i7 2600K @ 4.2Ghz, Asrock z77 extreme4, 16gb DDR3 @1866, 2 x 1TB, GTX 560 ti
Monitors: Asus VG236H, Dell U2713HM Headphones: Koss PortaPro, DT 770 80ohm, AT-AD700 | Steam profile
https://linustechtips.com/topic/38307-help-with-razer-carcharias/#findComment-492304
>Razer
I got my keyboard and mouse from razer for lik 3 years and ive got 0 problems until now xD. so all i got to do is disable the EuP on the bios and i got no problem right?
https://linustechtips.com/topic/38307-help-with-razer-carcharias/#findComment-492321
