I have an original Xbox controller that has the rubber coating on the wiring missing at a point up near the top of the controller cable but I am sure this controller still works.  Now if I put electrical tape over this exposed area is this enough to make it safe to use?  Is there anything else I can do?
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/382816-will-electrical-tape-be-enough/
should be fine, not much else you can do.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
I've had this happen a couple billion times. Always use electrical tape. Always works. Until the tear gets worse. Without it you wouldn't need to worry anyways.
edit
damn a few days old, sorry. :(
