I have been looking around i'd appreciate if anyone could give their opinion on this:
CPU: Intel Core i7-4790K
CPU Cooler:
Cooler Master Hyper 212 EVO
Motherboard: Gigabyte GA-Z97X-GAMING
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory
Storage:
     SSD: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
     HHD: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI Radeon R9 290X 4GB TWIN FROZR V
Phanteks Enthoo Pro ATX Full Tower Case
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular
Case Fans: 3 x Corsair SP140 quiet editions on the top, Same 2 on the front, Then AF 120's everywhere else
Thanks for the help
Edit: Main purposes gaming and some 3D rendering on architecture programs
PCpartpicker: https://pcpartpicker.com/user/Axees/saved/#view=Vg8v6h
https://linustechtips.com/topic/382800-input-on-build-idea/
It seems mostly fine, but it isn't a pcpartpicker build, so I can't tell as well as I would. One thing is that corsair ram is almost always overpriced, but I really don't know since you don't have links.
https://linustechtips.com/topic/382800-input-on-build-idea/#findComment-5168350
if you wanna game this is a very good "overkill" option the 290x you should wait for the 300 series
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/382800-input-on-build-idea/#findComment-5168353
It seems that you are going all out on this build from the specs but since you haven't posted a budget I'm not quite sure so I'm just going to assume that you are going all-out and you have a fairly large budget.
-GPU: If what you will be doing on this PC is not AMD specific then of you want the best Graphics card on the market and don't want to spend 5 billion dollars on a Titan, then an Nvidia card would be your best option.
    The GTX970 By Nvidia is, in most cases, cheaper the the R9 290X and offers slightly better performance in most cases. The GTX970 is also said the be the best value card on the market, seeing that it has the best price to performance ratio.
    The GTX980 is about $100 more and offers MUCH better performance than the R9 290X and will deliver a much more satisfying experience if you have the money.
    The GTX980Ti is about $100 more than the 980 and offers even much better performance then even the 980 and has 6GB of VRAM. This card will give you a lot of future compatibility of you are in a situation where you want to wait as long as possible until you have to update again.
    Then theres the Titan X. Which is basically the card you buy more than one of if you are a billionaire and don't care at all cbout price to performance and want every single bragging right possible.
-CPU/CPU cooler: I see that you have chosen the i7-4790K which is a great CPU. And, if you were wondering, that "K" at the end means that it is unlocked and is overclocking compatible. However, the cooler you have chosen doesn't give the best watercooling performance. You would be best off choosing one of the two options.
    I do want to overclock: If you do plan on overclocking your CPU then I would suggest in investing in a better cooler. An AIO watercooler would give you great overclocking performance over many other options.
    I do NOT want to overclock: If you don't want to overclock, then I would suggest getting the I7-4790 instead of the i7-4790K. These are essentially the same CPU except the one that I am suggesting is not unlocked and, therefore, you can not overclock it.  There is not point in buying an unlocked CPU if you are not going to overclock. This will save you some money that you can spend on other stuff like your GPU, peripherals, or other parts for your PC.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/382800-input-on-build-idea/#findComment-5173399
looks good, but of course have to ask the obligatory "do you really need an i7 / an i5 4690k will be fine for every game on the market"
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
https://linustechtips.com/topic/382800-input-on-build-idea/#findComment-5179158
