Question About Erasing Hard Drive
Go to solution Solved by Captain_WD,
~snip~
Hey whatishacks,
You should be able to do it (as long as you don't boot from it). Make sure you've backed up anything that you might want to keep from the drive elsewhere, go to Disk Management, navigate to the desired drive, right-click on all of the partitions and delete them (this will delete all data from the drive!!!). You should be left with black space that says "Unallocated Space". Right clock on it, set up a new partition, format it and you have a new, empty partition for everything you might need it for. :)
Captain_WD.
Hello
I built my gaming PC about 4 days ago, and I've bought a few games and am loving it.
I threw my broken laptops hard drive in it today, just to see if it worked, and it did.
Now, I want to use that second one for strictly music, videos, and pictures.
It's 250GB and has windows on it..
So my question is, Can i just right click and format it to erase it?  It's not my main drive.
IF not, can someone please provide a solution to erasing it!
I basically just want to go into it and make 2 folders for music and pictures
Main PC: 4690k // Z97 // R9 280 3GB // 8gb Ram // CM Elite 430 Case // 750 EVGA B PSU // 1TB HDD
Living Room "Console" PC: FX 8350 // 990a SLI Krait // R7 360 // 8gb Ram // HAF 912 // 750 EVGA B PSU // 1TB HDD
Future Plans:
find a 2nd monitor at a pawn shop
Sell/giveaway R7 360, move r9 280 into console PC, buy a better GPU for main PC.
https://linustechtips.com/topic/382633-question-about-erasing-hard-drive/
If the laptop drive (which you don't care about the data on at all) is all in one partition then I guess you can do that.
However, I'd go into the Windows Disk Manager (Manage Disk and Hard Drive Partitions or something) and carefully make sure that there's only one partition on the drive, then wipe it, then format it in Windows Explorer.
Sig under construction.
it says healthy, active, primary partition
Future Plans:
~snip~
Hey whatishacks,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
