Hey guys.....I have a old LGA775 system,which I basically savaged every old unused computer in my house,I rebuilt it last week,and in fact I did post a topic on it.....I savaged a e8400 from my family's unused s**t computer,so I put that in,also found some unused RAM,to bump the capacity to 4GB.I did a ever so slightly overclock on the CPU,from 3 to 3.05 GHz.There is a Geforce 210 (I know,very old,this is the earlier version with GDDR2) ,in which I also did a slight overclock by 50MHz on memory and the core,but even in games like Minecraft my speeds is jumping from 5FPS to 70FPS,then down again (settings wise,basically at low with 4 chunks) .I plan to get a new graphics card,but I WILL buy it used,because my budget is very tight,around 30 to 60 ish dollars,since my family is strict on how things work.This kinda isn't troubleshooting,but help?
Specs
Intel C2D E8400 @ 3.05GHz,cooled by a Xigmatek Apache III
Gigabyte GA-G41 Combo
Asus EN210 with 512 MB GDDR2
Some random case
Some random power supple
Some random Hitachi 80 (faceplam)GB SATA 2 hard drive
A freaking IDE optical drive
P.S:My random power supply does not have PCI-E power connectors,so....yeah
https://linustechtips.com/topic/382358-e8400-will-bottleneck/
Depending on the GPU possibly.
For one in that budget, probably not.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/382358-e8400-will-bottleneck/#findComment-5162720
I doubt anything manufactured within last 3 years (at least) will NOT get bottlenecked.
01111001 01101111 01110101 00100000 01101010 01110101 01110011 01110100 00100000 01110111 01100001 01110011 01110100 01100101 01100100 00100000 01111001 01101111 01110101 01110010 00100000 01110100 01101001 01101101 01100101 00100000 01100011 01101111 01101110 01110110 01100101 01110010 01110100 01101001 01101110 01100111 00100000 01110100 01101000 01101001 01110011
https://linustechtips.com/topic/382358-e8400-will-bottleneck/#findComment-5162752
Examples?It must be power saving though.
You can get a GTX 460 for about 60$ on ebay... Its not exactly "power saving" but it should be nicely balanced with the E8400.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/382358-e8400-will-bottleneck/#findComment-5162822
GTX460?That is a little too old for me.....if I am going for that I might need to get some used power supply to power it though.Will a 750 Ti bottleneck?
You can do get a 750ti but you will not be able to play most recent cpu heavy games cuz your frames will drop every time your cpu is busy with something. So i would not recommend it for gaming.
https://linustechtips.com/topic/382358-e8400-will-bottleneck/#findComment-5163885
