Ill will handle an SLI, just for the overclocking headroom 800W would be more safe, as 750 would be border line (expect a 600W load more or less, and add the lost performance so in worst case escenario, a 15% loss in power [efficiency] would mean 700W from the wall, being just limit for a 750W PSU), but it being gold rated, it will probably manage as it is quite efficient.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/381318-cooler-master-v750/#findComment-5150744
750W will be fine, SLI 980s I have seen pull a max of around 550W
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/381318-cooler-master-v750/#findComment-5151110
Hello,
http://pcpartpicker.com/p/f82PdC
I have this build here that i made and im just wondering if i decide to buy another gtx980 windforce in the future will CM V750 have enough power for gtx980 SLI?
Have you bought any of the components yet ? You buying from the USA ?
https://linustechtips.com/topic/381318-cooler-master-v750/#findComment-5151721
More then plenty. Even the 650W version would be enough.
"Have" and "made" are past tense so I'd assume that he already has everything and is just looking to add a second 980
"Rawr XD"
https://linustechtips.com/topic/381318-cooler-master-v750/#findComment-5153804
