This is my first ever build.
I intend to play games on 1080p with settings maxed out and some low-end content creation.
I also intend to mildly overclock my components.
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($120.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($109.99 @ NCIX US)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($177.89 @ OutletPC)
Video Card: PNY GeForce GTX 970 4GB XLR8 Video Card  ($319.99 @ SuperBiiz)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case  ($77.99 @ SuperBiiz)
Total: $1212.68
Generated by PCPartPicker 2015-06-05 18:10 EDT-0400
https://linustechtips.com/topic/381123-us1200-first-build/
all of this sounds good but i would get a all in one cooler
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148373
PCPartPicker part list: http://pcpartpicker.com/p/q4TLLk
Price breakdown by merchant: http://pcpartpicker.com/p/q4TLLk/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor  ($218.95 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.89 @ OutletPC)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($100.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.45 @ OutletPC)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($96.98 @ Newegg)
Total: $1195.12
Generated by PCPartPicker 2015-06-05 18:17 EDT-0400
~Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth - Oscar Wilde~
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148394
Total: $1195.12
CPU Cooler:
It's more expensive and air coolers are now just as good.
I don't plan to do an insane overclock anyway.
Liquid coolers are also louder.
RAM:
I want the memory to be black because OCD.
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148407
CPU Cooler:
RAM:
PCPartPicker part list: http://pcpartpicker.com/p/Dd7xdC
Price breakdown by merchant: http://pcpartpicker.com/p/Dd7xdC/by_merchant/
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  ($89.90 @ Newegg)
Memory: PNY XLR8 8GB (2 x 4GB) DDR3-1600 Memory  ($59.00 @ Amazon)
Total: $1194.14
Generated by PCPartPicker 2015-06-05 18:21 EDT-0400
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148429
Total: $1194.14
I want to future-proof my PC because I think some motivation will cause me to end up doing higher end content creation and thus I need more RAM.
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148453
Motherboard:
I want it to be black because OCD.
CPU Cooler:
I want to take off one fan from the Dark Rock Pro 3 and use it as another airflow fan.
RAM:
I don't like that RAM style.
Power Supply:
620W is a bit overkill.
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148462
I think all in ones look cooler and you can get cheep ones. If it is to loud get a corsair fan on it
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148471
The be quiet! cooler also looks cool and I won't really see it.
I can get cheap ones but they might have a higher chance of leaking and potentially killing my system and my money.
I also plan to use a fan from the be quiet! Cooler as an airflow fan.
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148502
This is far better:
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($107.88 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($319.99 @ SuperBiiz)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case  ($64.99 @ NCIX US)
Case Fan: Cooler Master JetFlo 95.0 CFM 120mm  Fan  ($11.99 @ Newegg)
Other: Silverstone PWM Fan Splitter ($6.99)
Total: $1129.87
Generated by PCPartPicker 2015-06-05 18:36 EDT-0400
You'll need a PWM fan splitter, so I added one. Use the Jet Flo fans on the CPU cooler and rear exhaust for a black color scheme.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148519
This is far better:
Total: $1129.87
Fans:
I'm morally opposed to Cooler Master, just deal with this fact.
Case:
I don't really like the look that much.
Power Supply:
I want it to have a smooth paint job because OCD.
RAM:
I like the ADATA RAM looks.
GPU:
It's more expensive and an internal style cooler shouldn't be used in a ITX case anyway.
https://linustechtips.com/topic/381123-us1200-first-build/#findComment-5148571
