Help me get a Mechanical Keyboard
R3DOPS
So finally after asking around for a cheep keyboard i am now settling with one that  has a bit of a higher price (110$ MAX). I'm looking for a keyboard with chary mx brown keys. Also if you can find something with a back light of any color that would be nice but not needed. I am looking for a keyboard that looks like the corsair vengeance k70. The fact that you can look at the sides and see under wit keys makes it look good for me. But we all have our picks. Tell me what you think i should get. also don't forget brown switches ;)
Also CANADIAN websites please
If you are willing to stretch your budget by $10, then you can get a Corsair K70 with Brown switches for $120.
http://www.amazon.com/dp/B00IYJD5CY
Nice but id like to see more if you have anything else you think is worthy send it to me, Thanks also not canada web
http://www.amazon.com/Logitech-Mechanical-Keyboard-Tactile-High-Speed/dp/B009C98NPY
Good keyboard, there is a review of it on Linus' channel if you want to watch it.
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
IS this a good one?
http://www.amazon.ca/QuickFire-Rapid-Tenkeyless-Mechanical-Keyboard-Switches/dp/B007VDKLLM/ref=lh_ni_t?ie=UTF8&psc=1&smid=A3DWYIK6Y9EEQB
Yes, I own a Cooler Master Quickfire Rapid of my own and it's wonderful.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Those are a favorite on this forum and many other places because they are that good. I'd recommend getting one. If you aren't 100% happy with that, keep an eye out on massdrop.
