Audio Leakage DT 880
ebones5
Hey guys,
Does anyone know of the audio leakage on the DT 880's? I want to do podcasting/YouTube and the headphones need to be quiet enough so that a cardioid mic cannot pic it up. If the leakage is too high, would you guys recommend the DT 770's?
Edit: 250 Ohm edition.
I've never really heard the leak from my K7xx so i think you should be good
People can sometimes hear my music from the next room and I don't usually listen terribly loud. I don't know how well a mic would pic it up, though. 770 is recommended if you're concerned.
I have a DT 990, which is close to the DT 880, paired with a blue yeti, and my mic hasn't been able to ever pick up audio leakage, I think you should be fine.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
Thanks guys! I was considering jumping on the 990's but I thought that would be even worse. Just in case though, I will end up getting the 770's.
