Here is my build. Spent over 100 research hours looking for parts. Not sure if Noctua NH-D14 is overkill or not, but anyways, I am planning to use this for gaming. I plan to overclock this to about 4.4 ghz and I hope that you guys like it. If there are any suggestions for improvement, that would be greatly appreciated
https://linustechtips.com/topic/379961-first-build/
I would say that the fan is a little over kill (I would get a cheep all in one water cooler). Are you sure you want green ram I would get the G. skill ram.  Other than that It looks good
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/379961-first-build/#findComment-5133712
You could get the R5 s here is a link to the one with a window
http://www.fractal-design.com/home/product/cases/define-series/define-s-window
https://linustechtips.com/topic/379961-first-build/#findComment-5133737
No need for all those LED fans. The green ram is quite ugly. Kingston or G.SKILL has some nice ram. Such an odd color scheme of black red and blue. For the CPU cooler anything from BeQuiet! Is good.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/379961-first-build/#findComment-5133772
Corsair makes green memory... WHA.
your profile pic and the comment made me burst out laughing.
https://linustechtips.com/topic/379961-first-build/#findComment-5133777
yes, it dose fit very well
https://linustechtips.com/topic/379961-first-build/#findComment-5133789
