I have learned a ton more since posting this around a day ago and now have an update.
MY questions are now, is 550W a good amount of power to feed this set up? , Will the graphics card be able to run newer games at a medium to high graphics level?, Do I need to pick up an after market cooler or not?, Is my Mother Board over board for my set up?
Case- www.newegg.com/.../Product.aspx
HDD- www.newegg.com/.../Product.aspx
Power Supply (550W)- www.newegg.com/.../Product.aspx
Ram(2x4gb=8gb)- www.newegg.com/.../Product.aspx
Mother Board(works with my cpu)- www.newegg.com/.../Product.aspx
CPU- www.newegg.com/.../Product.aspx
or maybe this one(would require me to find a new mother board)-http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
Graphics Card- www.newegg.com/.../Product.aspx
or the -http://www.newegg.com/Product/Product.aspx?Item=N82E16814121913
If you have any answers to my questions I would greatly appreciate it and if you have any suggestions I would appreciate those also.
Thanks,
          Brett C
https://linustechtips.com/topic/379632-help-please/
Please put this on PCPartPicker to make editing the build easier
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/379632-help-please/#findComment-5129978
Actually, OP. If you put this in PcPartPicker, it will tell you how much wattage it uses :P
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/379632-help-please/#findComment-5130042
Check these out for me if your willing to and thanks for the info and the website I had not found one this good before.
http://pcpartpicker.com/user/Brettc13/saved/nMqgXL
http://pcpartpicker.com/user/Brettc13/saved/8m4hP6
https://linustechtips.com/topic/379632-help-please/#findComment-5130682
Lol your Intel build is too basic and forget the AMD build won't help you in life
just hold on im coming
https://linustechtips.com/topic/379632-help-please/#findComment-5134784
here you go
http://pcpartpicker.com/p/FZThLk
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($241.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler ($17.22 @ Amazon)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($71.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory ($52.99 @ Newegg)
Storage: OCZ ARC 100 120GB 2.5" Solid State Drive ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.45 @ OutletPC)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card ($219.99 @ Micro Center)
Case: Thermaltake Chaser A31 ATX Mid Tower Case ($64.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($29.99 @ NCIX US)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($17.69 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($87.98 @ OutletPC)
Total: $917.23
Generated by PCPartPicker 2015-06-04 03:59 EDT-0400
Mine costs less and gives you the 4gb 960, a fast 120gb SSD, better case for 60 less, a Xeon processor. . works like a locked i7 with HT.. a cpu cooler to get the job done on that Xeon and a better Ram kit with boss heat sinks. and lastly a blue and black color scheme. . have fun gaming
https://linustechtips.com/topic/379632-help-please/#findComment-5134920
here you go
Total: $917.23
What about this
http://pcpartpicker.com/user/Brettc13/saved/YHY7YJ
https://linustechtips.com/topic/379632-help-please/#findComment-5135616
You don't want to run a system like this on a mediocre/poor PSU like the EVGA 500W. Just because it is 500W and EVGA does not mean it is good quality.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/379632-help-please/#findComment-5135802
What do you suggest?
As a minimum, XFX TS (made by Seasonic) perhaps, Antec HCG, any Seasonic or XFX really, or EVGA B2/GS/G2
https://linustechtips.com/topic/379632-help-please/#findComment-5136826
Did you check out the link below the quote to my PC build ?
Ah, sorry missed that. The NEX isn't great either if I'm honest, those suggestions would be better
https://linustechtips.com/topic/379632-help-please/#findComment-5136872
How about the
SeaSonic G Series 550-Watt ATX12V/EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply SSR-550RM
A very good psu. You may also want to consider an M12II 520W or HCG 520W or 620W. I believe the HCG 620W is on sale at the moment.
See my sig re 80+ ratings.
https://linustechtips.com/topic/379632-help-please/#findComment-5137048
But then again I trust the one I have selected right now because another member recommended it and it has an 80 + Gold rating. it's also go pretty good reviews. But thanks for the help.
The seasonic is better. The NEX is made by FSP, its not bad but it is far from great. It suffers from high ripple
https://linustechtips.com/topic/379632-help-please/#findComment-5137059
The HCG 620W looks like a good by with good ratings if you suggest I get it and not the seasonic then I'll pick up this one instead. Thanks
https://linustechtips.com/topic/379632-help-please/#findComment-5138514
Both are built by Seasonic. Both are good. The G series would be a better choice. Choice really comes down to pricing and budget.
https://linustechtips.com/topic/379632-help-please/#findComment-5138621
