Problems with Corsair Link
Go to solution Solved by yuh25,
Found the problem, I had the window too small and for some reason "Link" decided to have 3 "devices" per fan/pump so it only showed the top ones which happend to be stuck on 0, While the real ones were right down the bottom of the window.
Seems to be working fine and I can control everything again :D
So I only just noticed that corsair link isn't showing the fan RPM's and the LED's aren't on while using Windows 8. I'm using 1.0.5 firmware on the H100i and corsair link 2.3.4816.
Nothing should have changed since the last time it was working and I've checked all the connections.
The LED works on boot but dies once Windows loads up
3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITXDan A4-SFX, SX600-G, 120mm AIO.
https://linustechtips.com/topic/37963-problems-with-corsair-link/
Problems with LEDs are common on the H100i.
You might have to RMA it.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/37963-problems-with-corsair-link/#findComment-488127
Problems with the H100i are very common. RMA it and hope you get one of the "good" units.
CASE: BitFenix Prodigy | CPU:  i5 4570| CPU COOLER: Noctua NH-U12s | MOTHERBOARD: Asus H87-I Plus| RAM: Muskin Blackline 8GB | SSD: Samsung 830 128gb |
SSD: Samsung 840 128gb SSD(Games) | GPU: Asus R9 270X DCUII | PSU: Seasonic 660w | MONITORS: LG 23" IPS 5ms |
https://linustechtips.com/topic/37963-problems-with-corsair-link/#findComment-488161
two things:
one would be to try another USB port on the motherboard, re-initialize and retest.
two would be to try the new 2.44948
another from reading in the Corsair Forum was try and not have the color setting
too deep (255) seems any number other than 000 or 255 on the color slider tends
to have issues.
Change Log:
Version 2.4.4948-Beta
• LED configuration panel will hold settings after reboot/shutdown of the system.
• Firmware Update Improvements
• Progress information for the user
• Additional CRC verification step
• Automatic retry if an error occurs
• Revised the two default “Light” and “Dark” theme’s. “Light” is now default.
• White is now the default font color for the UI
• If you have manually saved the profile and not made any changes you will NOT be prompted to save again when exiting the program.
• Memory leaks fixed
• CPU Avg Temp and Activity labeled as such to mirror AFP naming
• LED mode change improved
• General options modes for Celsius and Fahrenheit cannot be unselected
• LED now remembers different “normal” and “cycle step 0” colors; these are NOT saved in the Lighting Node however, and must be saved in the profile (otherwise it will come up as black)
• LED temperature mode Fahrenheit bug corrected
• LEDs can now be controlled by load devices (e.g., CPU or AFP)
• LED mode is now correctly set when changing back to normal mode
• Fixed watchdog conflict with boot-loader
• LED Pulse mode works without profile having been saved
• Groups can be selectively hidden; alternately all formerly hidden groups can be shown
• Fixed spelling of Celsius and some other grammatical errors
Version 2.3.4816:
• Added support for Windows 8
• Windows 8 Support
• New Hardware Detection and Monitoring Engine
• Firmware flashing to Commander units prior to firmware 2.06 now supported
• CPU temperature for all AMD platforms now supported.
• Device Icon’s now have three selectable sizes
• Communication between multiple devices has been improved
 Corsair is usually running 30-45days on firmware/software revisions till the
issues are addressed.
airdeano
https://linustechtips.com/topic/37963-problems-with-corsair-link/#findComment-488855
I decided to try a firmware update which has fixed the LED issues but I still can't control the fan speeds.
@airdeano I tried changing the USB port which didn't seem to work and every time I uninstall CorsairLink and install the beta version it stays on the old one for some reason(I've tried rebooting before the install)
https://linustechtips.com/topic/37963-problems-with-corsair-link/#findComment-491231
https://linustechtips.com/topic/37963-problems-with-corsair-link/#findComment-496426
