As a gamer, I like many other gamers I assume, listen to music instead of most of the actual game sound.
My question is
What are some of the benefits of a sound card?
generally not, I normally have the game sounds 80% of the time, only when playing like FPS games do I have music on, unless my friends are on comms with me!
Sound card? no benefit at all, depends on what audio equipment you are using (such as high impedance headsets or 7.1 surround sound)
https://linustechtips.com/topic/379505-sound-cards/#findComment-5128259
that's weird haha, i can't play music while gaming, i have to have the game sounds playing or else i wont be in the "zone" if you know what i mean :P
a soundcard is only beneficial if you have headphones that need driving that your motherboard can't do. .....i think lol
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/379505-sound-cards/#findComment-5128314
yeah mostly if I play Battlefield and stuff, and not playing with friends I like to have music on, never for single player games though
https://linustechtips.com/topic/379505-sound-cards/#findComment-5128344
Don't think it would be worth for you
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/379505-sound-cards/#findComment-5141934
