This is the best way if you want to mod it yourself. Moding is fun and easy, go to home depot to get your window, they sale them for less then $11
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/3787-side-window/#findComment-46720
I'm not sure but it does not look like it, not sure if you are asking if the 650D door will go on the 500R or not but by looking at your case it looks like you could just go to home depot and buy a peace of acrylic and buy some 3m double sided clear tape model #4010, your looking at maybe $16 bucks at the most if you do it that way and the 3m tape is very very strong and that is not an understatement. I have a huge roll of it and it works super good on window modding.
https://linustechtips.com/topic/3787-side-window/#findComment-49103
I got an acrylic side panel window for my define r4 and I never look back. You should get some led strips if you are getting a side panel window because they make the inside of the case look awesome. Also use acrylic not glass because if the glass smashes you are screwed. Use some lovely acrylic.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/3787-side-window/#findComment-49353
