MSI Afterburner - how to monitor?
Guest Console Peasant
I have one monitor open but it doesnt display enough info about the system like I can't fit all 4 cores temps, usage, and gpu temps and usage into one graph, is there a way to open multiple instances? I usually have it on my second monitor..
I used to use hwinfo which was amazing but to complicated and half of the stuff it displays was useless to me..
Any alternatives? Also what else should I do to see how my pc is going after a good long while?
GPU-Z is good for monitoring GPU load and temps. You can set it to record the current, average, max and min of a variety of stats.
Realtemp is fairly simple for monitoring CPU temps.
You can use GPUz instead for GPU monitoring.
Comparison
"The of and to a in is I that it for you was with on as have but be they"
id prefer it all to be in one place like hwinfo
Comparison
then i can use msi for cpu... not bad
I use task manager for CPU, next to afterburner for GPU.
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
Comparison
can i get it to boot with windows?
I use the portable version so idk if you can or not.
For MSI Afterburner:
Go to Settings > General tab > Under General properties you will find Start with Windows tick box :)
For GPU-Z:
Click on the GPU icon which is at the top left of the window and and then click Load on Windows Startup
For GPU-Z:
beast
You can resize graph area for Afterburner like any other software. Or you can double click it and separate it from main window and resize then. Also worth mentioning is that you can enable/disable sensors you want to see.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
