So i'm building basically the same system as the one from the $2000 build guide linus did but im doing it in an air 540 and im water cooling it
i have it all planed out i am going to use Crystal Link but i cant decide on the color of the coolant the build is going to be fully black but i dont know what to get a Ice white Coolant or a Black coolant so i kinda need some help deciding what will look better
thanks guys
https://linustechtips.com/topic/37745-help-me-decide/
I think Ice white would look good.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/37745-help-me-decide/#findComment-484974
why not get white or black tubes and use distilled+biocide?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/37745-help-me-decide/#findComment-485004
i don't like that normal tubing i think it looks to clunky that's why i am going with crystal link so i can keep everything nice and tidy also i don't like colored tube because if i ever want to change the color it means i have to replace all the tube! thanks for the suggestion thought :)
https://linustechtips.com/topic/37745-help-me-decide/#findComment-485024
no problemo
https://linustechtips.com/topic/37745-help-me-decide/#findComment-485029
I just have to ask; Do you know what you're getting yourself into with acrylic tubing?
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/37745-help-me-decide/#findComment-485036
I wouldn't go with crystal link for the whole thing I would only use it for the tight spots in the CPU and motherboard area and GPU but not for a whole system because bitspower donesn't really make big sizes so you will need heaps of different types of fittings.
You can't walk out of your own story - Rango
https://linustechtips.com/topic/37745-help-me-decide/#findComment-486118
I was going to ask same thing as @Ghost. :) A complete Crys Link build would be a very advanced project. But, given that, I think the white coolant would pop. The black would just be lost in the rest of the black and be pretty "meh".
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/37745-help-me-decide/#findComment-487101
