If price is not a problem, than a custom loop would generally provide better cooling. De-liding the cpu itself, could lead to better temperatures.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/377392-coolest-water-cooler/#findComment-5101149
Those cooling systems are a little to insane for me airdeano but I will look into those more as they look cool!! They just aren't for me but thank you!
you asked for coldest. but if settling on ambient cooling, then any AIO/custom loop
can be available. they all pretty much run close in temperatures, till you start
throwing money at them. eventually, the point of reaping benefits will stop.
https://linustechtips.com/topic/377392-coolest-water-cooler/#findComment-5101369
