Ok so my friend wants to upgrade his GPU, and his current PC is well old... and I normally don't do any kind of partial upgrade or budget build... anyway his build is below. What GPU should he get?
        Operating System
            Windows 8 64-bit
        CPU
            Intel Core i3 3220 @ 3.30GHz
            Ivy Bridge 22nm Technology
        RAM
            8,00Gt Dual-Channel DDR3 @ 665MHz (9-9-9-24)
        Motherboard
            Acer Predator G3620
        Graphics
            1535MB NVIDIA GeForce GT 645 (Sapphire/PCPartner)
        Storage
            931GB Western Digital WDC WD10EZEX-22RKKA0 (SATA)
EDIT: ops ops ops ops sry guys!! forgot....
Euros (finland) is currency and max 300e but cheaper is better
PLEASE QUOTE OR TAG (WITH @) ME IF YOU REALLY REALLY REALLY WANT ME TO REPLY!!!!!!!
Also if your issue is solved don't forget to mark the thread as solved!
Peace!!! from a random person in the tech's god forsaken land (named Finland or as I like to call it sarcastically FUNland)
https://linustechtips.com/topic/376169-need-help-friend-considering-update/
        Operating System
            Windows 8 64-bit
        CPU
        RAM
        Motherboard
            Acer Predator G3620
        Graphics
        Storage
Budget? Currency?
Shamelessly bumping!
  • 2 weeks later...
Shamelessly bumping #2
