Weird Car Issue?
I changed my cars oil.... Took it to my bowling center... It died... like completely dead I asked cameron (the mechanic) for a jump... would not jump. Went up in his car to battery king and got a new battery. Worked... Got to the store... it wouldn't start. Jumped it. Worked perfect. Best part is works awesome now... as if the alternator went out but fixed itself. @techswede
https://linustechtips.com/topic/375750-weird-car-issue/
I had a weird issue in my car the other day - sitting at a traffic light, my RPMs just dropped, and my car started shaking. RPMs went back up and I couldn't repeat the issue.
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5081909
It seems as if the problem went away now cause it is holding a charge very good.
If you put a volt meter on your accu + and - poll, and you start the car, then you can see if its charging.
Ofc you need to measure in DC not AC.
Other test you can do, start the car, take of the + poll from the Battery.
If it fauls out, then there could be an issue with the alternator still.
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5081934
Had an issue like that. Turns out it were some corroded cables on the main plug.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5081986
Probably a loose connection somewhere. Have a quick look around to see if anything is loose
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5081993
I checked it, seems to be nothing loose although, now it is working perfect, charging and holding the charge.
Maybe it was in chock after getting some fresh oil xD
Oh well. You could either attack it with a multimeter to see if you can find anything or see if the problem reappears
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5082049
still the 95 mustang?
possibly the 20 year old battery cables. ford used a real small gauged wire for
the starter, charging and grounding circuits. when we'd bump up compression
on the 5.0L autocross cars, we'd use the 00 welding cable to allow the battery
to fully energize the starter (high compression made for hard starts). even
upgrading to a 2ga cable for the ground and starter and 16ga from alternator
to starter solenoid should help out a lot on stock cars (copper does
breakdown after years of atmospheric/corrosion).
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5082422
Yeah I gotta agree here. Copper cables don't last forever in both the marine and auto worlds.
Had to replace all the heavy cabling in my firebird last month as the cable in the terminals had corroded so badly it would kick out over speed bumps.
2ga marine cable makes for excellent replacements, especially with crimped ends and top post lugs.
Mind you my poor 'bird has been hacked together by morons for who knows how long so I'm hunting down issues every other day.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/375750-weird-car-issue/#findComment-5118035
