Hi guys I'm thinking of buying this because I do light video editing and play minecraft on my computer, and the lag is starting to bother me.
http://www.ncix.ca/products/?sku=72476&vpn=GV-N610SL-1GI&manufacture=Gigabyte&promoid=1311
My computer right now has a 270w power supply because its a pre-build HP AMD athlon 2.7 ghz system. With integrated graphics that are horrible.
The page for the video card shows a minimum power requirement of 300w.
Will the card work in my system? I have a pcie lane open, and this card doesn't require any power plugged into it..
I'd prefer not to upgrade my psu btw.
https://linustechtips.com/topic/37546-minimum-power-requirements/
It should work fine. The GT 610 has the maximum power draw of only 29 watts.
The card isn't worth buying imo.
Save up for a better card.
https://linustechtips.com/topic/37546-minimum-power-requirements/#findComment-482601
Preferably, I would not do it. Your system will let you know if your drawing to much by shutting down. (Correct me if I'm wrong please!)
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/37546-minimum-power-requirements/#findComment-482604
