I NEED A CASE
Mullen
Im building a new pc with a red and black color scheme, I've put the phantom 410 on the parts list but I'm not sure on it. I was going to go for the nzxt noctis 450 but it is a bit to expensive so does anybody have an idea for a really nice red and black case for around the price of the phantom 410, if not I'll just get the phantom. Thanks
Yours Sincerely,
The Beast,
Sean Mullen
Heyyo,
As much as I love NZXT? I gotta give my respect to Fractal Design. They also torture Linus which is hilarious.
Check out the Fractal Design Define R5.
If you don't care about 5.25" bays? (DVD Drive Bays) the Fractal Design Define S is an even better design.
If you really want red and black though? I don't think Fractal Design does that so you may have to get that NZXT case. I own an NZXT Phantom 530 and it is a really damn solid case. The only hing I dislike is how they shaped the top and front for 140mm fan sizes.
My NZXT Phantom 530 case. Red and black and costs about the same as that NZXT 440.
https://pcpartpicker.com/b/sNPscf
Heyyo,
My PC Build: https://pcpartpicker.com/b/sNPscf
My Android Phone: Exodus Android on my OnePlus One 64bit in Sandstone Black in a Ringke Fusion clear & slim protective case
