Planing first build
Go to solution Solved by improbablepants,
Same price, way more power
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.99 @ SuperBiiz)
Motherboard: MSI B85M-E45 Micro ATX LGA1150 Motherboard  ($54.99 @ Directron)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card  ($268.98 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Total: $687.89
Generated by PCPartPicker 2015-05-27 09:40 EDT-0400
One question tho - Why dont you have an HDD?
EDIT: Here is one with an HDD, only $50 more. You will need it, and be grateful for it
Total: $739.56
Generated by PCPartPicker 2015-05-27 09:43 EDT-0400
You can play GTA5 on it, you'd get abouit 30-40ish fps maxed out, but you can get stable 60 with lower details.
Its a good build, but i would get a 240GB SSD minimum, 120GB fill up really quickly and youve got no HDD, Even if the PC will go slower, get a 1TB HDD and dont get ssd, as GTAV alone will fill up over 1/2 of that SSD.
@Andrew.A remember to follow ur topics.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/374785-planing-first-build/#findComment-5069322
I am first time builder and I want to see your opinion about my system that I am planing to build. And could I play GTA V on it ?
Looks fine. If you want to play GTA V in higher resolutions try to buty better GPU maybe R9 290, and it's better to take i5 4690k with z97 motherboard, so you can OC it if needed. Otherwise looks good. Maybe 16gb of ram (in future, for now it's good)
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/374785-planing-first-build/#findComment-5069332
Total: $687.89
Total: $739.56
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/374785-planing-first-build/#findComment-5069364
Same price range, way more power
Total: $687.89
I have a  tight budget, so I am planing to put HDD after some time.
https://linustechtips.com/topic/374785-planing-first-build/#findComment-5069381
