Can someone please help me find a 6 pin to duel 8 pin adapter? Preferably from the United Kingdom.
Thanks ~ Matt.
Not sure its possible
You could get a 6 pin to 8pin
and molex to 8 pin
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069065
This doesn't seem safe. If you've used all your connectors on your PSU, then I would recommend getting a better PSU.
and molex to 8 pin
I have a 500W power supply to power a Overclocked 780ti, I know it sounds crazy but I made a post on this forum and a moderator replied he did the same and it worked. My power supply only came with 1 6 Pin connector, I have many molex connectors. I just thought it would be easier to use 1 connector.
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069084
I dont think a 6 pin can provide enough power as they are only rated for a certain wattage (think its like 75 or something cant remember)
You will need additional power so either need to change PSU or get a molex to 8 pin
(I think)
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069099
(I think)
Should I get 2 molex adapters then?
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069110
It would be much easier to just get a few molex to 8 pin adapters. Though the graphics card may run on a six pin, in the long run it just isn't safe.
I've built 3 PC's, but none for myself... In fact, I'm using an iMac that my dad bought for me as my desktop. Awkward...
Please don't say "SSD drive." By doing so, you are literally saying "Solid State Drive Drive" and causing my brain cells to commit suicide. The same applies to HDD (Hard Disk Drive) and PCIe (Peripheral Component Interconnect Express).
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069111
Sure if you have enough free molex connnectors
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069113
I have
3x molex connectors
1x 6 pin
2x Sata
I would get a 6 pin to 8pin and a molex to 8 pin (because you will need 2x molex per 8 pin)
What PSU is this? it doesnt sound particularly high end
Also bear in mind, that a 780ti is rated for around 250 watts so make sure you are not asking too much of the PSU
It should be fine though
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069216
What is the PSU?
Cooler Master 500W
Ac Input 220-240V 7A 50Hz
DC Ouput      +3.3V     +5V      +12V1    +12V2     -12        +5VSB
                          22A       20A       20A         20A        0.8A       2.5A
Max Output     130W                 360W                     9.6W     12.5W
Literally that was everything.
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069288
Cooler Master 500W
Cooler master what? 500W doesn't tell us much
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069295
You thought about getting a new PSU?
I can't afford it, I just spent £300 on the graphics card. Hahaha I thought it was the manufacture number but I found it it was the model, it is the...
Cooler Master RS-500-PSAP-JR
https://linustechtips.com/topic/374769-help-finding-connectors/#findComment-5069336
