now to find one with green led
could I possibly add leds inside the gpu
If you found a 12v LED then I don't see why you couldn't pull off of the 6 or 8 pin connector...
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
Btw is it windforce cooler rev 1 or 2.
Listen if you care.
Rev. 2 most likely because this is the GTX 770.
Damn im losing it today, ive made like 5 tech mistakes, i, i think im turning into a wannabe. If i fully change then dont hesitate do what must be done, tell my parents that they should sell the shitty mac and buy a gtx titan for every linus tech forum member.
Listen if you care.
