So my brilliant mother decided to do the laundry and washed up my USB drive with my pants.
Haven't plugged it into anything yet. Used the hair blower for a min, then dumped it into rice.
Anything else to be done?
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/
Open it up
<THE SILENT ASSASSIN>CPU(Intel i5-4690K)||COOLER(corsair H100i)||MOB(asus Maximus VII Hero ATX)||RAM(16gb of corsair vengeance)||STORAGE(Intel 530 128gb)(Samsung 850 Pro 500gb)(WD 2tb Black)||GRAPHICS(2 x Asus strix 970)||CASE(Nzxt H440)||PSU(Corsair RM750W)>http://pcpartpicker.com/b/Bbpbt6
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5060904
I've washed a USB drive in my pants twice now. Just let it dry before trying to use it.
[rant]Also, it wasn't your brilliant mother who left the USB drive in your pants. If you're so smart, do your own laundry.[/rant]
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5061122
yea been there
leave it for a day or 2
it will dry up
no harm done
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5061204
Yes, but I'm assuming he never specifically put the pants into whichever pile/whatever was to be washed.
Sig under construction.
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5061473
Seriously you are 16. Mistakes happen. Dont leave shit in your pants you don't want ruined if you are not responsible enough to do your own laundry
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5061565
I was at school and before I left I told her to not do the laundry I would do it myself whe I got back.
Don't jump into random conclusions especially on others life. Ask before you give a personal opinion.
https://linustechtips.com/topic/374149-washed-up-usb-30-drive/#findComment-5062021
