My brother needs some help but I dont remember the fizics bs.
"A boat , wich will need to carry a 56 kg girl, is from logs. Each log is 20kg and the density 878 kg/m3. ( free fall acceleration is 10m/s2).
1. One log density (answer - cm^3)
2. The girls weight (in N(newtons))
3. How many logs will the boat need so the girl can swim in a lake.
Two trains are going facing each other - one is going 54 km/h and the other one is going 72 km/h. The first trains passenger notices that the second train pases in 4 secs. What is the lenght of the second train?
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/
1. density 0.878 g/cm^3
2. 56 x 10 = 560 N
Im working on the others lmao
The other half is when you do the other half.
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054568
Skip question #1 and #2 because you said she just needs to swim in the lake and she doesn't need a boat to do that. That is your answer for question #3. Is this a trick question given by his teacher?  It smells like it.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054571
No it needs to be done. I remember my teacher. A fucking butcher.
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054584
Well I am just saying that my answer isn't incorrect.  If the lake/water is there the girl can just jump into it and swim. LOL!
What if the girl doesnt know how to swim? You want her to drown? What a cruel person you are.
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054615
In my recommendation she would be swimming close to shore so she would have a better shot at not drowning and being saved if she started to have issues.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054644
What if the girl is an extremist and is like 20 km away from the shore.
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054655
Potatoes *-*
3. 3 logs i believe
4. v=d/t
 d= t x d    4 x 72 = 288 m
now give me potato pls
the 4th one should be in kN. Only the answer 560N was right lol.(its an internet site so it automaticly tells you if its correct). But thats just a miscommunication because I have to translate this 420 shit from my mother language to english.
half-potato-isolated-white-background-cl
NAZIS WILL RISE.
https://linustechtips.com/topic/373661-help-with-fizics/#findComment-5054693
