Does capping FPS helps or stresses cpu?
Solved by ForsakenLive,
Why cap it?
It's not like the GPU is being mean to the CPU and stressing it in any way. The GPU depends on what the CPU is doing, the CPU will do the compute part of the game, and pass instructions on to the GPU, which then proceeds to render them.
See it like the CPU takes the load, and the GPU gets its part to do on the game. The GPU is way faster, in this case, and it gets the job done easily, then it gets bored until the CPU finishes what it has to do.
With frame capping you are only telling the GPU to do even less. Either at 20fps or 120fps the CPU has to handle the same amount of data to the GPU, you aren't helping it by crippling the experience.
