Hello,
I've got an issue with my air cooling in my case CM K280 (bad airflow) anyways. I have 3 120mm fans, one in the front, second one on the side panel which is pulling air into the case and an rear exhaust for taking out the hot air.
What options do I have?
https://linustechtips.com/topic/373558-air-cooling-help/
I prefer to have my side panel fan exhausting gpu air so it's not bouncing around in the case and heating up your cpu. You could try rear and front intakes with side exhaust but I don't know how much good it will do you
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5053467
If I'm not mistaken you could add a fan or two to the top as well?
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5053491
No top fan. There is no place for it.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5053615
Buy new case. If those are your only places for fans, getting better ones won't help that much.
I am getting the Fractal Design R5 soon.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5053621
good call. money much better spent
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5053766
Yeah, :D anyways what shall I do with the side case fan? Shall I leave at pull or change it to push?
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5054154
I have mine exhausting air out the case on the side panel but it depends on how much heat your components are putting out. I've never used a 560 so I dont know what kind of heat they put out  I found that it helped lower my gpu load temps and my cpu temps since my ambient case temps were a little lower. try it both ways and see what you get.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5054428
Okay. I will try that. Thanks for the help. :)
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5054468
I've never used a 560 so I dont know what kind of heat they put out (...)
I don't know about a regular 560, but a 560 Ti gets pretty damn hot. According to Wikipedia, the 560 has a slightly lower TDP than a 560 Ti, being at roughly the level of a 970...
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5055405
I've got an Asus gtx 560 directcu ii.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5055438
The ASUS DirectCU II is quite a good cooler, which will help. Anyway, the exact heat output of your GPU doesn't really matter. 0ld_Chicken's suggestion is a bit unconventional, but it makes perfect sense that if you exhaust air next to the hottest component in the case, which is nearly always going to be the graphics card, it'll help temperatures.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5055470
Ugh, define "hot". Stock 560Ti max temp 75C with Furmark and fan speed limited to 45%.
E: I mean stock clocks, its with DirectU II cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5062885
Max temp is 63C while 46% fan speed. :) Using heaven.
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5063699
All things are relative. In a worst case scenario, with no case fans and quite a few other heat-generating components mounted close to it, as is sadly still the case in my rig, it'll hit 90 degrees with clockwork regularity, in both games and benchmarks. I'll get a new case delivered tomorrow or the day after, so I should see those temps drop soon, but at the moment they're rather high...
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5067721
Still, that could be scenario with other GPUs aswell, not particulary with 560Ti. This is first time I've heard it considered "hot" card. For me it was way cooler than previous blower card (EVGA 8800GT).
https://linustechtips.com/topic/373558-air-cooling-help/#findComment-5068206
