Heey Guys,
So im gonna build my first PC ever but my budget is 500 USD, so i know this isnt much but you can build a decent pc with it.
So what is want is a Intel PC who can run Gta 5, also i want it to be upgradable so that i dont get stuck with my CPU or something.
Thanks!
https://linustechtips.com/topic/373424-first-pc-build-need-some-help/
Heey Guys,
Thanks!
Do you need an OS or any peripherals?
http://pcpartpicker.com/p/LL2mpgthis is my shot.
http://pcpartpicker.com/p/DTC6gs
lowest i could get it, as gta 5 needs a decent gpu
maybe a 750 ti, but thats not going to give a great experience (will be a lot cheaper, and probs close to 500 usd)
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
Honestly don't recommend Intel for budget gaming. It takes up too much of the budget, which you should be spending on the GPU as GTA is very demanding on that side.
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
