I'm not sure if this is the correct subforum, but I have all my parts pretty much confirmed, except I found an issue with the motherboard I had in mind initially, which was mostly about availability... I might be overclocking in the future and I won't be using CrossFire / SLI.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($235.99 @ Amazon)
Motherboard: ??
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($349.99 @ Amazon)
Case: Rosewill BLACKHAWK-BLUE ATX Mid Tower Case  ($83.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($65.99 @ Amazon)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $941.42
Whats the best motherboard I can get, keeping it under $1050? Preferably I would like it to be a pre-discount price, if that makes sense. Thanks!
https://linustechtips.com/topic/372607-help-with-motherboard/
Any Z97 motherboard. Choose one that suits your budget and has the prettiest colours. They are all compatible with overclocking and all perform basically the same.
[spoiler=REDWING]  REDWING   | Custom Hard Line Water Cooling Loop   |   Intel i7-4790K @ 4.7Ghz   |   Asus Maximus VII Ranger   |   Corsair Dominator Platinum DDR3-2400 2x8GB   |   2 x Gigabyte GTX970 G1 Gaming (SLI)   |   Corsair AX860i   |   Samsung 850 Pro 512GB   |   Corsair Obsidian 750D   |   Corsair K95 RGB & M65 RGB   |   Samsung SyncMaster S27B370
Project Redwing Build Log
[spoiler=ZedNAS] 'ZedNAS' Home NAS Build   |   Intel Xeon E3 1231 v3   |   ASRock Rack E3C224D4I   |   Kingston KVR16E11/8I 2x8GB   |   Corsair HX750   |   6 x HGST Deskstar NAS 4TB 7200RPM HDD   |   Fractal Design Node 304 mITX Black   |   FreeNAS w/ PleX   |   ZFS Raid-Z2 (16TB Effective)   |
https://linustechtips.com/topic/372607-help-with-motherboard/#findComment-5042531
Asus Z97-C
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/372607-help-with-motherboard/#findComment-5042562
Asus Z97-Pro Gamer or Z97-A/USB3.1 (with lower budget)
CPU collection: i7-6700K, 2x-i7-5960x, i7-3930K, i7-4770K, i7-3770K, i7-2600K, i7-980X  AMD PII X4 965 BE C2, x4 965 BE C3, X4 970 BE, x4 975 BE, x4 980 BE, X6 1090T BE, x6 1100T BE, FX-8120 95W, FX-8120 12W, FX-8150, FX-4300, FX-6300, FX-8300, FX-8320, FX-8350, FX-8370E, FX-8370, FX-9370, FX-9590, A8-3870K, A8-5600K, A10-6800B, A10-6800K, A10-7700K, A10-7850K, A10-7870K, Athlon x4 860K, Athlon 5150. RIIIE, RIVE, RVE, Maximus5Extreme, M6F, M6E, M7H, C4F, C4E, C5F, C5F-Z, Crossblade Ranger
https://linustechtips.com/topic/372607-help-with-motherboard/#findComment-5042563
Right, okay. Thanks for the heads up!  :) Do you have any recommendations for a case that the price-point?
Thanks!
Check some of these out, HardwareCanucks on youtoob have beautiful reviews on cases.
http://pcpartpicker.com/parts/compare/bitfenix-case-bfcron300kkwskrp%2Cfractal-design-case-fdcadefr4blow%2Cfractal-design-case-fdcadefsbk%2Cnzxt-case-cas340wbb1/
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/372607-help-with-motherboard/#findComment-5042618
