650D with H80i Airflow?
Solved by Theo,
So u would recommend have the the h80 as an intake in the rear and have the top two 120mm fan as the exhaust. So should I get NF-S12A for the two top fans and do you think replacing the corsair fans on the h80i with NF-F12 would be benefical?
Its what i have so thats what ill recommend! for the NF-S12A's ive no idea cause i havent looked them up, but what you can do is buy the NF-F12's, put them on the H80 and put the corsair fans on the top of the case and run them at 900rpm or something where they will be quiet and move a decent amount of air, and then if you arent happy with that you can buy more fans but try and make the most of what you got!
