Silent anti-dust case
Go to solution Solved by SkywardKkalox,
Define S, Define r4, r5.
I'm planning to buy a new pc that is quiet and doesn't get dusty easily
The configuration is this: http://pcpartpicker.com/p/kfryBm
The budget for the case is U$90 or less
I kind like the Thermaltake Urban S31 (no side window version), but I'm open to suggestions
I really like the Fractal Design cases, especially the Define S, but for some reason it's massively overpriced here in Brazil, with prices around R$3700 (U$1200).
More expensive than the Cooler Master Cosmos II, for comparison, R$2100 (U$700).
And it's very hard to find, but thanks for the suggestions.
