So, battery expansion...
Go to solution Solved by ShadowCaptain,
:P I like my s4, though if anybody wants to donate an s6 or lg g4 ill gladly except xD.
Yeah but throwing things off roofs is fun too :3
No its still a good phone so just get a new battery
Previously, I made a thread accounting my degenerative battery life and shutdowns and random percentage <50% here
So, now,  upon further inspection, I have discovered opening the back cover off my (2 year) s4 that the battery now does not sit flush against the compartment. So, this is a potential battery expansion case. How should I go about dealing with this predicament?
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/371400-so-battery-expansion/
replace the battery.
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028156
Short and simple, I like it. For curiosity's sake what do you think will happen if I continue using the battery?
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028181
Please don't. Bloating Li-ion/LiPo batteries are very dangerous. It could explode or catch fire anytime.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028209
this
or buy a new phone, and throw your S4 off a roof for the lels
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028222
this
s4 is still a good phone... It costs a fair amount even used.
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028228
never said it wasn't.. its still an option though
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028231
It's actually more likely just to leak than actually explode or catch fire, if it does leak it is going to destroy the internals.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028245
I wasn't gonna anyway,but yeah don't need no explosions here. Or leaks
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028250
this
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028252
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028255
I like your style so you're getting the green box.totally just didn't accidentally press the button  :ph34r:  GODDAMN ENGLISH MISTAKEs
Thus begins Adam's adventure in finding a genuine Samsung battery
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028267
Lithium based rechargeable batteries are a different beast. They will usually vent, explode or catch fire when abused.
60FPS Microwave
https://linustechtips.com/topic/371400-so-battery-expansion/#findComment-5028474
