So I am looking for a network switch. I was wondering what is the difference between a smart and unmanaged switch was? What does the smart network switch do that an unmanaged does not. What do you like like better?
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/371054-network-switches/
smart switch has a GUI, you can change some settings on the web interface (using an allocated IP) unmanaged, means it doesn't need any configuration done to it.
https://linustechtips.com/topic/371054-network-switches/#findComment-5023608
What do you prefer and like.  How does the smart switch different from the managed switches
Chase B
https://linustechtips.com/topic/371054-network-switches/#findComment-5023615
Unmanaged switches basically do nothing except allow for more connections.
Managed (SMART) Are the same thing except that can be programmed to have Vlans and other things. Mostly in the IT environment.
All you need is an unmanaged switch though. They are cheap and when you need more ports, that's all you need.
https://linustechtips.com/topic/371054-network-switches/#findComment-5023617
Would I see the benefit in smart
Chase B
https://linustechtips.com/topic/371054-network-switches/#findComment-5023625
Depends. What is your network like? Do you need to manage different computers separately and manage speed etc?
If you need more connections only for your other computer etc, all you need is a cheap gigabit unmanaged switch.
https://linustechtips.com/topic/371054-network-switches/#findComment-5023634
I use both. But managed/smart switches tend to have annoying little fans. Managed switches are pretty similar to smart switches, but have more features. You can create VLANs, port security and so on.
Here is a video that explains unmanaged and managed:
There is a difference between managed and smart.
Smart has limited features, while managed can do more just than VLANs. Managed switches come in different versions, such as layer 2 and layer 3.
The layer 3 can do routing, such as a router.
https://linustechtips.com/topic/371054-network-switches/#findComment-5023642
I have a detail of my new network in the new house on post #10 http://linustechtips.com/main/topic/370962-printer-help/#entry5023428
READ THAT POST FIRST
I was thinking of adding a better switch in the closet and then having another one in the office where we need more ports. What about putting a firewall in the closet and no switch? what do you think.
Chase B
https://linustechtips.com/topic/371054-network-switches/#findComment-5023664
Yeah, but I didn't want to go into that much detail when he is determining between like no feature and features.
https://linustechtips.com/topic/371054-network-switches/#findComment-5023666
I just dont really know
Chase B
https://linustechtips.com/topic/371054-network-switches/#findComment-5023670
Unmanaged switches are basically plug and play. You basically plug the cables in and it works. Smart switches will have a web interface to change settings such as creating VLANs or setting up link aggregation. Managed switches will usually have a CLI (command line interface) where you access it via a serial console or telnet or SSH. The unmanaged switches are usually the cheapest. Smart switches will be in the middle. But managed switches can be several thousands of dollars and I am almost certain you wont need it. For you I recommend a smart switch and if you want I can recommend some good switches of any of these tree.
-toxicnos
https://linustechtips.com/topic/371054-network-switches/#findComment-5026657
-toxicnos
Please List some smart switches Under 150 with 5-16 ports. More Ports the better
Chase B
https://linustechtips.com/topic/371054-network-switches/#findComment-5029015
If you have to ask what the difference is between the different types of switches then you'll only need an unmanaged switch. For your home network an unmanaged gigabit switch is more than enough.
CPU: Core i7 4770K @ 3.5GHz Motherboard: ASUS Z87-EXPERT RAM: Corsair Vengeance 32GB (4x8GB) 1600 MHz GPU(s): EVGA GTX 980 Classified SLI Case: Coolermaster HAF X Storage: Samsung 256 GB 840 Pro, 2x2TB WD Caviar Black, 2x4TB WD Green PSU: Corsair AX860 860W Display: LG 31MU97-B 4K(4096x2160) and Dell S2716DG 27in 2K 1440p 144hz, Cooling: Noctua NH-D15 Keyboard: Corsair K70 with Cherry MX Blue switches Mouse: Razer Naga Epic Chroma and Death Adder Chroma Sound:Audioengine D1 Dac and Sennheiser HD650 Operating System: Win 10 Pro
https://linustechtips.com/topic/371054-network-switches/#findComment-5042380
The diference between unmanaged and managed/smart switches in a nutshell is:
Unmanaged: A crossroad without traffic lights.
Managed/Smart: A crossroad with traffic lights controlling what goes where. (all needs to be configured though)
https://linustechtips.com/topic/371054-network-switches/#findComment-5044698
