hay guyz what do u think of this power supply
    Sentey® Power Supply 850w 80 Plus Bronze Mbp850-hs Metal Blade Power 850 Watts / 140mm Sleeve Bearing Fan / Autoswitching 100-240 Voltage / Active PFC / Single +12v Rail / Certified Power Cord / 5 Years Warranty - Computer Power Supply - Desktop Power Supply - Power Supply 850w - 80 Plus Power Supply
because i well get a gtx 970 Sli is it enough though and do i take the modular or non modular
https://linustechtips.com/topic/370391-power-supply/
junk
get a seasonic 850
or xfx 850
or evga or corsair or cooler master or superflower
https://linustechtips.com/topic/370391-power-supply/#findComment-5015314
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/370391-power-supply/#findComment-5015809
hay guyz i want power supply under 100$
i found this
KENTEK 800 Watt 800W 120mm Fan ATX Power Supply 12V 2.3 EPS12V 2.92 SLI-ready PCI-Express SATA 20/24 PIN Intel AMD by KENTEK
Don't get PSUs of those nonsense brands. The ones you want are from well-known brands like Antec, EVGA, Seasonic, Super Flower... not generic like Sentey and Kentek
"Rawr XD"
https://linustechtips.com/topic/370391-power-supply/#findComment-5018190
