Help with CPU Decision
Go to solution Solved by flipped_bit,
I'd go with the 4690K over the 4670K.  The 4690K is part of the latest Haswell architecture refresh so it's the most up-to-date.  Likely the main benefit is its use of a better TIM (thermal interface material) that leads to more consistent overclocks.  Overclocking with the 4670K is more hit and miss.
That said, the i7-2600 is still a pretty solid chip.  The jump from the 2600 to the 4690K would be negligible in most applications.  The i7-2600 is more than enough to feed a 270x GPU.  I'd look for a used board (if you don't want to stick with your current one) and call it a day at least until Skylake comes out.
Hi everyone. Firstly, thanks for taking the time to read this. I am hoping to get a few more experienced heads to point me in the right direction.
I purchased a high-end boxstore PC 4 years ago, it was a Gateway with an Acer mATX mobo and an i7-2600 processor. I have since transplanted the internals with my other upgrades (better PSU, recently purchased R9 270X, SSD) into a new Fractal Design R4 case to allow me more freedom with my upgrades (and a case with some filters!!). The Acer mATX mobo quite frankly is a piece of crap and I have had a hard time finding any information on it. LED and Power/Reset pins aren't labeled and it is generally a pain in the ass to work with.
So my question is this... Should I just purchase a compatible 1155 LGA socket Mobo and call it a day, or would it be worth upgrading to an i5-4460 and going with a 1150 LGA board à la some Z97 offering. I have never done any overclocking before (hence my i5-4460 suggestion) but would potentially be interested in giving it a go with an i5-4670k or similar. Is the ~$80 CAD difference in price worth it?
Cheers for the input!
https://linustechtips.com/topic/370264-help-with-cpu-decision/
With DX12 coming and all of the newly implemented CPU features, it'll be quite the benefit to upgrade.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/370264-help-with-cpu-decision/#findComment-5013645
What is the difference between the 4690K and the 4670K? is it only the power usage? or is their more?
The only differences are that the 4670k is older and clocked lower then 4690k, about the power usage, I dont know, but there are only very small differences between these 2 processors.
Here's some comparison:
http://cpuboss.com/cpus/Intel-Core-i5-4690K-vs-Intel-Core-i5-4670K
https://linustechtips.com/topic/370264-help-with-cpu-decision/#findComment-5013757
The only differences are that the 4670k is older and clocked lower then 4690k, about the power usage, I dont know, but there are only very small f+differences between these 2 processors.
Here's some comparison between these 2:
oh hahahha thanks, I just made a Topic about it :)
to game or not to game, that`s the question
https://linustechtips.com/topic/370264-help-with-cpu-decision/#findComment-5013762
Xeon E3-1241 @3.9GHz, 1.07V | Asus Z97-E/USB 3.1 | G.Skill Ripjaws X 8GB (2x4GB) DDR3-1600 | MSI RX 480 Gaming X 4GB @1350MHz/2150MHz, 1.09V/.975V | Crucial MX100 256GB | WD Blue 1TB 7200RPM | EVGA 750W G2 80+ Gold | CM Hyper 212+ w/ Noctua F12 | Phanteks Enthoo Pro M | Windows 10 Retail
https://linustechtips.com/topic/370264-help-with-cpu-decision/#findComment-5013789
I would get the 4690k, overclocking isn't at all as hard as it used to be. As for motherboard, I would buy an entry tier feature packed board, something like a Asus Hero board, so you get a nice but not expensive board to work with, you want a board with a easy to understand and well flushed out bios so you have a easier time overclocking, and something with good support behind it. There might be a better choice than that board, that was just a quick reference.
https://linustechtips.com/topic/370264-help-with-cpu-decision/#findComment-5014018
