Hi,
Im trying to play games on my galaxy note 2 (custom stock rom 4.4.2) with my xbox 360 controller. I connected it via an otg cable and the lights on the controller keeps blinking. The controller doesnt work at all.
I can connect other devices such as a mouse or a keyboard but the controller doesnt work. And yes the controller is not broken.
Can anyone help me?
Thx
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/369754-android-x360-controller-not-working/
Just something that happens, I tried using my xbox 360 controller with my nexus 4 and it wouldn't work for some reason. However, when I tried my nexus 7 it worked flawlessly, I never managed to find a solution to the problem with my nexus 4.
It could be the ROM perhaps? Would it be fairly easy to change roms or is it not that desparate? @dionkoffie
