With father's day coming up I am looking to get my dad a better PC case. Currently he has drives just laying out with cables connected. My budget is $200 CAD but I can go to $300 CAD if needed. I am looking for a server case if possible. Must fit atx board.
Edit - He has 8 drives in use currently but would likely want to plug in more.
Edited by KirbyTech
https://linustechtips.com/topic/369605-case-for-father/
Mhmm how much are those Intel NUCs ?
Sorry I thought you need a new PC
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004411
It would help to list his system's specs.
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004465
I don't know them, I know he has an ATX mobo and a 500w evga psu. That is about it, other than the like 8 drives he has plugged in and another maybe 15 of working and non working sitting on his desk.
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004482
Which one of those has the max hdd support? Also any server cases you can think of?
The Define R4/R5 both support up to 8 3.5in drives and have 2 2.5in drive in the back.
But there are two 5.25in slot so you can easily mount an additional two to three drives with the right adapters.
The Silenco 652 supports 7 3.5in drives can support anywhere between 7 to 10 drives including the 5.25in slot
H440 supports max of 6 (I think) 3.5in drive and 8 (I think) 2.5in drives
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004549
I think out of those the R4 would make the most sense since it is cheaper than the R5.
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004597
Give or take, both cases are very similar in terms of internal layouts but the R5 gives some additional features like a better dust filter system and a better ssd mounting system, but your call ultimately
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004625
The way he keeps things dust will get in no matter what case he has. Currently he has his side panel off..
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004637
What?
Why does he have 8 HDDs?  Why do you guys not have a NAS if you need that much storage?
My guess is that he has a bunch of smaller capacity HDDs.  Buy him a new large capacity HDD and a case:
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($96.47 @ Newegg Canada)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($149.98 @ Newegg Canada)
Total: $246.45
Generated by PCPartPicker 2015-05-19 10:45 EDT-0400
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004718
-snip-
His computer is the home server. The drives are either 3 or 4 tb ones. Only smaller drive is the 1 tb boot drive, which my mother has ordered an ssd for him after listening to me. The Enthoo Pro can not hold enough drives. If buying a bigger drive was the solution don't you think I would have done that?
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004759
I am just covering the bases... you never mentioned the capacity of his eight freakin' drives...lol... what are you guys storing?  Do you do surveillance for CSIS(Canadian NSA) or something?
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004777
Thanks this is exactly what I was looking for and under budget too.
We are storing movies, music, pictures tons of them, then each person has their own folder that shows up as a network drive. We have home sureillance video kept on there plus it is in a raid config with about 75-80% efficiency space wise.
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004806
Very cool.  :)
https://linustechtips.com/topic/369605-case-for-father/#findComment-5004860
