Do you need RAM with a heat spreader when overclocking?
Solved by Toxicable,
I'm building a new PC. I need an 8GB RAM module for it and I found two, one with a heat spreader and one without. They have a slight difference in price and I am going to be overclocking the system once it's done. My question is, do I need the heat spreader for the RAM, or go without one?
If you're looking to overclock your RAM - which is a pointless idea- then you'd want the heat spreaders, otherwise they don't really do much if you're just overclocking CPU and/or GPU
