For gaming you shouldn't get more than an i5 4690k because anything more than that you won't see much of an improvement.
https://linustechtips.com/topic/369233-help-choosing-cpu/#findComment-4999217
Guys!! i need your help!
1. for a gaming pc, what is better? intel core i7 5820k or 5930k??
2. do you think that with overclocking should i watercool a titan x? if yes what water cooler do you reccomend?
4690k or 4790k
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/369233-help-choosing-cpu/#findComment-4999226
The i7-4790K is currently the fastest chip when it comes to gaming, with the extra threads helping futureproofing further.
A Titan X will provide you the highest frame rates while also skipping all the inherent issues that multi-GPU setups have.
Can't speak for watercooling as I run high-end aircooling myself, though.
https://linustechtips.com/topic/369233-help-choosing-cpu/#findComment-5002663
Go with i7 4790k and TitanX. Try to avoid SLIsbecause you can always upgread one GPU but if you have at the start 2gpus therefore you cant upgreade with just one more card.
Watercooling? Yes if you are experience builder and if you will overclock that bad boy. Otherwise, great air cooler would do. (Except CPU Watercool it but best is to use custom loop than AIO Watercooler)
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/369233-help-choosing-cpu/#findComment-5016318
