PSU not able to power system under load
Solved by blackadder,
ok,is this a new build? find where clicking is coming from. Check fan, could be bearings. Make sure nothing fell in the psu. If possible change out psu and retest. If it is the psu, unless you bought it many moons ago you can rma, it sucks but, it is what it is.Got the same problem on a different circuit. Clicking and gpu power jumping between 44% and 106%
rohleder00 ·
Old_Liver ·
Posted in Laptops and Pre-Built Systems0 -
2
2
ghifrank ·
Posted in Troubleshooting1 -
1
1
V_1313 ·
Posted in Troubleshooting3 -
IR76 ·
Posted in Programs, Apps and Websites10 -
The Blue Cryptid ·
