~180USD Headset for FPS
I you REALLY want to throw money at a gamey headset I think the consensus is that the HyperX Cloud II's are probably your best bet. Really the "portable" aspect is all about the size and in a given size range they are all going to be more or less the same. Same with durable. Don't break them! Personally I would go with a cheaper build and just plan on buying a new set every so often.
If you are seriously focusing on LAN events then wireless is something you should forget about completely. Too much interference including the possibility that someone else is using the same set. Closed backs, with good sound isolation, is essential. I'd prefer a separate mic just because you CAN buy a separate mic which makes it easier to replace (or replace the headphones when they break and keep the mic, and vice versa).
For FPS games I prefer open backed headphones but I'd never take them to a LAN event.
