Cannot Find CPU Cable From Power Supply....Need Help
By
Snapy1
in Troubleshooting
in Troubleshooting
Solved by Shyxlol,
This one is from the individual sleeved kit but the connector should have CPU (or EPS) written on it. Also, it should be the only one you can split into 4+4 (not sure about that. Might be you can, might be you can't)
kisserik93 ·
Posted in Peripherals3 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
