h100i temp problem?
Go to solution Solved by jamesisninja,
Yeah, I don't see a problem here, those are pretty normal..
So here's my situation.
I am concerned with the h100i i'm using.
Ambient temp: 27.4 C
h100i water temp: 29.1 C (2 fans running @ 835 rpm)
3770k idle: 34~35 C
other numbers:
GTX 660ti: 32 C
motherboard: 31 C
Using MSI's OC Genie my cpu overclocks to 4.2ghz
CPU idle: 36~38 C
W/ Prime95: 64~67 C (2 fans pushing out ~1900rpm)
W/out OC Genie
CPU (stock) Prime95: 64~67 C (2 fans pushing out ~1900rpm)
I can't tell if this cooler is really working for me or not.
Also, i just recently reapplied thermal paste using the 'pea' method. I also added extra washers to the backplate to keep it tight. before, i had it loose and cpu temp reported pretty much the same.
comments are greatly appreciated.
https://linustechtips.com/topic/36790-h100i-temp-problem/
try overclocking,add more voltage,that's the only way to really know.
better heatsinks separate themselves when you put them under more stress,not less.
also what's the room ambient temp.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/36790-h100i-temp-problem/#findComment-472296
The TIM under the IHS may be uneven.
https://linustechtips.com/topic/36790-h100i-temp-problem/#findComment-472297
3770k idle: 34~35 C
other numbers:
GTX 660ti: 32 C
motherboard: 31 C
CPU idle: 36~38 C
W/out OC Genie
Everything looks fine to me here. Maybe you just have an awesome chip or your OC isn't acctually being applied.
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/36790-h100i-temp-problem/#findComment-472301
1.2 volts is good, but probably can be better.
https://linustechtips.com/topic/36790-h100i-temp-problem/#findComment-472348
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/36790-h100i-temp-problem/#findComment-472738
