I Have Been Set £500 To Build A Gaming Computer For My Self And I Have The Parts That I Will Be Using
Do You Like Them?
CPU - Intel Pentium G3258
CPU Cooler - Cooler Master Hyper TX3
Thermal Paste - Arctic Silver 5
Motherboard - Asus Z97 PRO GAMER
RAM - Patriot Viper 3 8GB (1X8GB)
Storage 1 - Samsung 840 Evo 120gb SSD
Storage 2 - Seagate Barracuda 250GB HDD
GPU - Gigabyte GeForce GTX 750 TI
Case - Corsair SPEC-01 RED
PSU - Corsair CX430M
http://uk.pcpartpicker.com/p/Kss4kL
https://linustechtips.com/topic/367577-what-i-will-be-making/
you bought it already?
https://linustechtips.com/topic/367577-what-i-will-be-making/#findComment-4976962
@GeeZillon Like It Says £500 Budget And Used For Gaming
That dosent really answer the question. What you're saying there half imply s that you've brought it and half imply s that you already have it.
Im guessing that you dont have it yet and would suggest a slightly different build.
This has a much better CPU and GPU
The GPU 'should' come with molex to 4 pin connectors
You dont need a CPU cooler or thermal past, the CPU comes with both
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  (£86.35 @ Amazon UK)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  (£61.16 @ Scan.co.uk)
Memory: Patriot Viper 3 8GB (1 x 8GB) DDR3-1600 Memory  (£40.70 @ Amazon UK)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  (£41.94 @ Aria PC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  (£147.46 @ Ebuyer)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  (£39.99 @ Amazon UK)
Total: £485.16
Generated by PCPartPicker 2015-05-16 10:53 BST+0100
https://linustechtips.com/topic/367577-what-i-will-be-making/#findComment-4976980
Getting better but the 980x is still a more powerful GPU and like I said before, You dont need a CPU cooler, or thermal compound - if you're going with a i3 - which is what pretty much every person here would suggest. 2 cores aint gonna last you very long, even if you can overclock it.
https://linustechtips.com/topic/367577-what-i-will-be-making/#findComment-4976997
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (£90.04 @ CCL Computers)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£31.98 @ Ebuyer)
Memory: Kingston Fury Series 8GB (1 x 8GB) DDR3-1600 Memory  (£41.69 @ CCL Computers)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card  (£203.99 @ Scan.co.uk)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£33.78 @ Aria PC)
Total: £510.22
Generated by PCPartPicker 2015-05-16 11:06 BST+0100
Wayyyy Stronger than what you built for the same price.
https://linustechtips.com/topic/367577-what-i-will-be-making/#findComment-4977008
